[GRASS-user] r.to.vect error message
Markus Metz markus.metz.giswork at googlemail.com
Wed Jul 27 11:43:06 EDT 2011
On Wed, Jul 27, 2011 at 3:34 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Wed, 27 Jul 2011, Rebecca Bennett wrote:
>> Thanks fro replying. Hmm no I'm using the standard 6.4.1 distro on Ubuntu
>> 10.4 :(
> Rebecca,
>  The distribution and GRASS version has nothing to do with it.
The GRASS version has indeed something to with it because the reported
error is an out-of-memory error and GRASS 7 needs much less memory to
build topology for 3D points (about 5% of the memory needed in GRASS
6.x).
Markus M
>> Can I work round this? I don't really have time to build GRASS 7 on this
>> machine...
>  Yep. I've no idea if there's a Ubuntu repository that installs a pre-built
> GRASS. If there is, it's probably built without the large file option. If
> so, see if you can grab the source and look for '--enable-largefile' in the
> configuration options. Otherwise, it will be worth your time to recompile
> the source using that option. It will allow GRASS to use the available
> memory on your machine rather than the default (which I believe is 64M).
>  This is one reason why building from source (or using a package manager
> that lets you build on your local machines) is a good idea. Not everyone
> needs the options you do, and your hardware is not the same as everyone
> else's. Building your applications using your server/workstation ensures
> that they work for you.
> Hope this helps,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
