[GRASS-user] Re: WinGrass nightly build problems
Daniel Victoria daniel.victoria at gmail.com
Fri Jul 29 09:53:25 EDT 2011
Another thing I noticed that might help debug this problem. The error
message says that it's looking for some module in c:/osgeo4w/usr....
But I don't have that directory in my computer! Could it be some
leftover install from another grass version or gdal / qgis / python
etc?
Thanks
Daniel
On Fri, Jul 29, 2011 at 10:49 AM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi all,
> Just installed the latest wingrass nightly build [1] and I'm getting
> an error when I try to select the grass database directory or when I
> click on a location. Also, the mapsets for each location are not
> displayed in the mapset window.
> The error in the console windows is:
> Traceback (most recent call last):
>  File "C:\Program Files (x86)\GRASS 7.0.SVN\etc\gui\wxpython\gis_set.py", line
> 635, in OnSelectLocation
>    self.listOfLocations[self.lblocations.GetSelection()]))
> 599, in UpdateMapsets
>    gisdbase = self.gisdbase)
>  File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/gui/wxpython/gui
> _modules/gcmd.py", line 610, in RunCommand
> _modules/gcmd.py", line 610, in <lambda>
>  File "C:\Program Files (x86)\GRASS 7.0.SVN\etc\gui\wxpython\gui_modules\utils.
> py", line 664, in DecodeString
>    return string.decode('utf-8')
>  File "C:\Program Files (x86)\GRASS 7.0.SVN\Python25\lib\encodings\utf_8.py", l
> ine 16, in decode
>    return codecs.utf_8_decode(input, errors, True)
> UnicodeDecodeError: 'utf8' codec can't decode bytes in position 34-35: invalid d
> ata
> I'm using a Brazilian Portuguese version of Win7. Anyone seen this error?
> Thanks
> Daniel
> [1] - http://wingrass.fsv.cvut.cz/grass70/
