[GRASS-user] ARC GRID File Won't Import
Daniel Victoria daniel.victoria at gmail.com
Fri Jul 29 17:42:14 EDT 2011
I believe r.in.gdal will import ArcGrids. did you try that?
On 7/29/11, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>    I'm going to use a different DEM source (this one from the USGS NED). It
> is stored as an arc/info grid file so I thought the appropriate module to
> use is r.in.arc. I'm using the wxPthon GUI, and specifying the hdr.adf, but
> the import fails because required parameters are not found.
>    No other file in that subdirectory works, either.
>    I'm almost certain that I used r.in.arc previously with these files and
> specified the hdr.adf as the information source. However, I'm not seeing
> what I'm doing incorrectly here and would appreciate a clue stick.
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
