[GRASS-user] mentor required to help publish a GRASS addon (DEM)
Rebecca Bennett rabennett at ymail.com
Tue Jun 7 06:15:32 EDT 2011
Hi Andras,
Thanks for responding so quickly! I have read the information here
http://trac.osgeo.org/grass/wiki/HowToContribute but I'm not exactly certain
what the mentor needs to do. I think they need previous experience of the
GRASS-svn, code and uploading to the wiki? I have not contributed before so will
need someone to help guide me through the process.
I don't know if the mentor is required to check / run the code as well. I
regularly use it for my work and have recently distributed it to a few of my
colleagues to test with good results. However, a GRASS expert opinion of it
would be most useful!
I should also mention that I have only run the script on linux (Ubuntu 64 bit)
so some advice on developing a windows compatible version would be helpful as
most of my contemporaries use GRASS on windows.
Please let me know if you are interested and I will send through the script and
readme notes for you to look at.
Best wishes,
Rebecca
To: Rebecca Bennett <rabennett at ymail.com>
Sent: Tue, 7 June, 2011 11:01:37
Subject: Re: [GRASS-user] mentor required to help publish a GRASS addon (DEM)
Dear Rebecca,
What do you need exactly?
The stuff is very interesting.
bw
András
011.06.07. 11:02:29 dátumon Rebecca Bennett <rabennett at ymail.com> írta:
Dear GRASS users,
>I have been working on automating a technique known as Local Relief Modelling
>(see http://www.ag-caa.de/caanlde/paperdownload/hesse.pdf). The process allows
>the extraction of microtopographic changes from a DEM (in this case
>archaeological remains) and is very useful in areas of large topographic
>variation e.g mountain ranges where small scale features are masked by large
>shadows in shaded relief models.
>I have written and extensively tested a bash script in GRASS 6.4 as part of my
>doctoral work and would like to make it publicly available so that other
>researchers can access and use this tool. To do this I need a mentor, so I was
>wondering if anyone could spare a few hours  to help me?
>I look forward to hearing from you,
>Best wishes,
>Rebecca Bennett
>Postgraduate Researcher (Archaeology Group)
>School of Applied Sciences, Bournemouth University
Bödőcs András, PhD
ELTE Régészettudományi Intézet
Térinformatika Labor
Budapest, H-1088
Múzeum krt. 4/b.
T: +36-1-4116554, +36-1-4855200/2910
F: +36-1-4116553
E-mail: bodocs.andras at btk.elte.hu
www: http://regeszet.elte.hu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110607/ca499967/attachment.html
