[GRASS-user] r.mapcalc questions
Frank Broniewski brfr at metrico.lu
Wed Jun 8 09:13:15 EDT 2011
I have some questions concerning the use of r.mapcalc. I have a DEM made
by r.surf.contour using the approach in the wiki (multiplying by
100000)[1]. Now when calculating back the original values I wonder about
the values given by r.info. Calculation is done like so within the
wxpython map calculator: r.mapcalc dtm_surf = dtm_surf.100k / 100000.0
Now r.info tells me:
Data Type:    DCELL
which seems OK, but
Range of data:    min = 130  max = 555
-> shouldn't these be float values after calculation?
and the comments
I definitely typed 100000.0! Where're my .0s? A quick visual
verification with r.slope.aspect shows some terracing effects. That lets
me suspect that the conversion to a DEM float raster failed somehow -
but why?
I'm using the osgeo4w build on windows 7 64. GRASS GIS version is 6.4.1
(2011).
Many thanks
Frank
[1] http://grass.osgeo.org/wiki/Contour_lines_to_DEM
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
