[GRASS-user] How to draw the earthquake-magtintude map...
Saber Razmjooei razmjooeis at faunalia.co.uk
Wed Jun 15 18:46:42 EDT 2011
It's a bit off topic and an item in my wishlist, but will be interesting
to have  AnuGA integrated in GRASS.
http://sourceforge.net/projects/anuga/
http://en.wikipedia.org/wiki/ANUGA_Hydro
and a tsunami risk assessment in New Zealand:
http://www.aon.com/attachments/reinsurance/200812_ab_analytics_nz_tsunami.pdf
We did a plugin a while back in QGIS for preprocessing the gis layers
for AnuGA.
Cheers
Saber
On Wed, 2011-06-15 at 12:51 +0300, Micha Silver wrote:
> On 15/06/2011 10:46, sgw00412 at nifty.com wrote:
> > Dear grass users
> > I'm from Japan and begginer user of grass GIS.
> > I tried to draw earthquake map of tohoku Japan.
> > First, I summarized of some earthquake data, for example lat, lon, depth and m
> > agnitude.
> > lon     lat    depth Magnitude
> > 139.9,  37.7,  10,  3.1
> > 141.0,  35.8,  10,  2.6
> > 142.7,  40.8,  20,  4.4
> > Second, this text data was imported to grass data by using v.in.ascii, as foll
> > ows;
> > cat data.txt | v.in.ascii fs=',' cat=0 x=1 y=2 out=quake columns='x double pre
> > cision, y double precision, depth integer,  mag double precision'
> > So, I typed to 'v.vect quake'
> > These points where the earthquake were displayed by cross (x) .
> > Next, I tried to display new map as circle size of earthquake-magnitude.
> You probably want here:
> d.vect.thematic map=quake col=mag type=point
> themetype=graduated_points icon=basic/circle
> There are more options for coloring, etc.
> > v.vect quake size=magnitude
> > However, unsuccessful....What should I do?
> > Yasuo shimada ( Japan weathere association )
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> > This mail was received via Mail-SeCure System.
> Hevra Logo
> Micha Silver
> Arava Development Co
> 052-3665918
> http://www.surfaces.co.il
