[GRASS-user] Re: How to draw the earthquake-magtintude map...
sgw00412 at nifty.com sgw00412 at nifty.com
Wed Jun 15 22:14:51 EDT 2011
Dear all,
I wish to express my gratitude to your some advices.
I understood the command that drew in circle.
Also, I understood the magnitude was not simple.
It explains the process...:
(1)
d.vect.thematic map=quake column=mag type=point themetype=graduated_points ico
n=basic/circle
...It succeeded.
(2)
d.vect map=quake size_column=mag icon=basic/circle
...error message "Sorry, <size_column> is not a valid parameter"
(3)
d.vect map=quake size=mag icon=basic/circle
...It succeeded. but very small symbolsize...
(4)
d.vect map=quake size=10^(11+1.5*mag) icon=basic/circle
...error message "token (' syntax error..."...
Why ?
(5)
d.vect map=quake size=10^mag icon=basic/circle
...It succeeded.
Yasuo shimada ( Japan weather association )
----- Original Message -----
>Date: Wed, 15 Jun 2011 16:46:28 +0900 (JST)
>From: sgw00412 at nifty.com
>To: grass-user at lists.osgeo.org
>Subject: How to draw the earthquake-magtintude map...
>Dear grass users
>I'm from Japan and begginer user of grass GIS.
>I tried to draw earthquake map of tohoku Japan.
>First, I summarized of some earthquake data, for example lat, lon, depth and
m
>agnitude.
>lon     lat    depth Magnitude
>139.9,  37.7,  10,  3.1
>141.0,  35.8,  10,  2.6
>142.7,  40.8,  20,  4.4
>Second, this text data was imported to grass data by using v.in.ascii, as fol
l
>ows;
>cat data.txt | v.in.ascii fs=',' cat=0 x=1 y=2 out=quake columns='x double pr
e
>cision, y double precision, depth integer,  mag double precision'
>So, I typed to 'v.vect quake'
>These points where the earthquake were displayed by cross (x) .
>Next, I tried to display new map as circle size of earthquake-magnitude.
>v.vect quake size=magnitude
>However, unsuccessful....What should I do?
>Yasuo shimada ( Japan weathere association )
