[GRASS-user] Re: Where should the file python-wxversion be located?
jentjr jentjr at gmail.com
Tue Jun 21 23:18:08 EDT 2011
Hi Tom,
I'm not sure if this helps you, but I have GRASS7 running on Ubuntu 11.04
and this is where python-wxversion is located on my machine.
justinjent at ubuntu:~$ locate wxversion
/usr/lib/python2.6/dist-packages/wxversion.py
/usr/lib/python2.6/dist-packages/wxversion.pyc
/usr/lib/python2.7/dist-packages/wxversion.py
/usr/lib/python2.7/dist-packages/wxversion.pyc
/usr/share/doc/python-wxversion
/usr/share/doc/python-wxversion/changelog.Debian.gz
/usr/share/doc/python-wxversion/copyright
/usr/share/pyshared-data/python-wxversion
/var/lib/dpkg/info/python-wxversion.list
/var/lib/dpkg/info/python-wxversion.md5sums
/var/lib/dpkg/info/python-wxversion.postinst
/var/lib/dpkg/info/python-wxversion.preinst
/var/lib/dpkg/info/python-wxversion.prerm
justinjent at ubuntu:~$gedit /usr/share/pyshared-data/python-wxversion
[python-package]
format = 1
python-version = 2.6, 2.7
[pycentral]
version = 0.6.11
include-links = 0
[files]
/usr/lib/python2.6/dist-packages/wxversion.py=f
/usr/lib/python2.7/dist-packages/wxversion.py=f
I followed this page when I compiled GRASS7
<http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu>
Justin Jent
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Where-should-the-file-python-wxversion-be-located-tp6502667p6502776.html
Sent from the Grass - Users mailing list archive at Nabble.com.
