[GRASS-user] v.net.iso setup - whats missing?
Markus Metz markus.metz.giswork at googlemail.com
Wed Jun 22 03:24:31 EDT 2011
On Wed, Jun 22, 2011 at 5:25 AM, RKiTect <evan.apostol at gmail.com> wrote:
> I am having trouble getting this function to work properly. I ran the v.net
> function to connect my centres to my network (presumably sucsessfully).
You used v.net operation=connect ?
> Then
> i input the arc file and centre (point) files into the alayer=1, nlayer=2
> respectivly, set my categories and distances, and when i run it, nothing is
> allocated.
It is not clear what you mean with files, can you post the command you
used? The output of v.net must be the input for v.net.iso, and the
numbers used for alayer and nlayer with v.net.iso must be the same
like those used with v.net.
> My output network's attribute table consists of one column, with
> a row for each line segment, and 1's for each segment... However, the roads
> that are inaccessible b/c of region clip are removed, so i beleive the
> routing process is running, i just cant seem to get it to split the network
> using distances... I think i am missings something fairly simple, but cannot
> seem to get it... Any help is much appreciated; i have been trying to figure
> this out through trial and error for over a week, and am getting tired! :/
Have you tried different distances (the costs option of v.net,iso)?
Markus M
