[GRASS-user] r.colors -e for G3d?
Soeren Gebbert soerengebbert at googlemail.com
Sun Jun 26 12:43:03 EDT 2011
>> While doing this i plan to implement two more modules:
>> r3.retile and r3.colors. r3.colors can be used to assign a color table
>> to a raster3d map (its an enhancement to r.colors to support 3d raster
>> too, like r.univar and r3.univar). Because g3d uses the same color
>> table and functions as the raster library these color tables can be
>> exchanged between raster and raster3d maps. Maybe this is the
>> function you are looking for?
> yes, exactly.
Done. :)
r3.colors with "-e" support is now available in grass7 svn as well as
r3.colors.out. Color tables can be exchanged between raster and volume
maps. The implementation of the color table equalization was easier as
i thought. The modules r3.colors and r3.colors.out are implemented as
Glynn suggested.
A backport to grass6 is not planned.
Best regards
Soeren
