[GRASS-user] Re: r.stream.extract with external flow accumulation maps
jentjr jentjr at gmail.com
Mon Jun 27 16:24:57 EDT 2011
I also tried that by first setting the region equal to the elevation map and
then using r.mapcalc to create a new accumulation map. Both the elevation
and accumulation maps have the same spatial extent and resolution, but I
still get the error.
I believe that the flow accumulation grid was produced using ArcHydro. I put
the link to the data set that I am using below if anyone wants to try it
out.
http://www.horizon-systems.com/nhdplus/HSC-wth21.php
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-stream-extract-with-external-flow-accumulation-maps-tp6518518p6522188.html
Sent from the Grass - Users mailing list archive at Nabble.com.
