[GRASS-user] Ps.map vlegend
Martin Album Ytre-Eide Martin.Album.Ytre-Eide at nrpa.no
Tue Mar 1 05:40:33 EST 2011
Hello.
When using "area fill patterns" (http://grass.osgeo.org/wiki/AreaFillPatterns#Example_Pattern_files) together with vlegend in ps.map trouble appears when customising the patterns to my need. You can pretty much get the patterns you desire with the aid of pwith and scale option, but the problem is that vlegend does not follow up. Vlegend somewhat scales things down making the legend lock like something else than what is seen in the map. One can change the size of the legend by using width and fontsize but the pattern will still have the same size.
Is there any solution to this problem other than generating your own legend?
Martin
