[GRASS-user] v.in.e00 Error: -6.5svn
Rich Shepard rshepard at appl-ecosys.com
Tue Mar 1 18:39:30 EST 2011
   I've hit this once before and have no idea how to overcome the error.
Please advise.
/usr/local/grass-6.5.svn/scripts/v.in.e00: line 178: 32155 Aborted
avcimport "$GIS_OPT_FILE" "$E00SHORTNAME" 2> /dev/null > /dev/null
E00 Compressed ASCII found. Will uncompress first...
...converted to Arc Coverage in current directory
Importing lines...
Over-riding projection check
Layer: ARC
WARNING: Column name changed: 'NV_ROADS#' -> 'NV_ROADS_'
WARNING: Column name changed: 'NV_ROADS-ID' -> 'NV_ROADS_ID'
DBMI-DBF driver error:
Column 'FNODE_' already exists (duplicate name)
Cannot create table.
Error in db_execute_immediate()
ERROR: Unable to create table: 'create table roads (cat integer, UserId
        integer, FNODE_ integer, TNODE_ integer, LPOLY_ integer, RPOLY_
        integer, LENGTH double precision, NV_ROADS_ integer, NV_ROADS_ID
        integer, NV_RDSWA83 integer, NV_RDSWA_1 integer, PREFIX varchar ( 2
        ), NAME varchar ( 30 ), TYPE varchar ( 4 ), SUFFIX varchar ( 2 ),
        FCC varchar ( 3 ), FIPS varchar ( 11 ))'
ERROR: An error occurred while running v.in.ogr
Rich
