[GRASS-user] d.barscale draws bar up to right edge of map
Luigi Ponti lponti at inbox.com
Wed Mar 2 12:15:53 EST 2011
Dear list,
I have found problems with d.barscale mentioned in bug tracker only for
grass 7.
When trying to draw a scale bar using PNG driver in grass6.4.svn on
windows7 (couple of months old -- it is the last version I have that
does not need to delete vectors twice, see
http://trac.osgeo.org/grass/ticket/1158), the scale bar starts ok at
specified coordinates but then keeps going up to the right edge of the
map -- see sample output:
https://docs.google.com/leaf?id=0B0EpsfMZ-IZYMmY3YzdjMDQtNjA4Yy00YzU2LTgzZDktMGZhODcwODkzODRk&sort=name&layout=list&num=50
No text is drawn even if one tries to move it on top of the bar with -t.
This happens with any kind of combination of flags.
Is there a known way around this?
Kind regards and thank you,
Luigi
