[GRASS-user] v.in.ascii: DBMI-DBF driver error
Nick Jachowski njachowski at gmail.com
Thu Mar 10 23:02:44 EST 2011
Thanks for the help Markus, but when I try it on my computer I still get the
same error message:
GRASS 6.4.0RC5 (latlong_coral):~/grassdata/latlong_coral > v.in.ascii
input=kyy.csv out=kyy skip=1 fs=, cat=3
Scanning input for column types...
Maximum input row length: 86
Maximum number of columns: 9
Minimum number of columns: 8
DBMI-DBF driver error:
Cannot create dbf database: ~/grassdata/latlong_coral/PERMANENT/dbf/
WARNING: Unable to open database <~/grassdata/latlong_coral/PERMANENT/dbf/>
         by driver <dbf>
ERROR: Unable to open database <~/grassdata/latlong_coral/PERMANENT/dbf/>
       by driver <dbf>
I'm a complete newbie to the db part of GRASS; was I supposed to do anything
special during the installation to allow the dbf driver to work?
I've tried this on two separate machines and have the same error message in
both, one is running GRASS 6.4.0RC5 on Ubuntu 9.10 the other is running
GRASS 6.4.0 on Ubuntu 10.04 in a vm.
Sorry to bother the list again!
Nick
On Fri, Mar 11, 2011 at 12:13 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Mar 10, 2011 at 3:45 PM, Nick Jachowski <njachowski at gmail.com>
> wrote:
> > Hi all,
> > I'm trying to use v.in.ascii and I'm getting a "DBMI-DBF driver error."
> > input=kyy.csv out=kyy skip=1 fs=, columns='x, y, cat int' cat=3
> ... this cannot work since you did not specify the types for x and y.
> Doing so, I get:
> v.in.ascii input=kyy.csv out=kyy skip=1 fs=, columns='x double
> precision, y double precision, cat int' cat=3
> Column: 1 type: double
> Column: 2 type: double
> Column: 3 type: integer
> Column: 4 type: string length: 3
> Column: 5 type: string length: 3
> Column: 6 type: double
> Column: 7 type: double
> Column: 8 type: double
> Column: 9 type: double
> WARNING: Table <kyy> linked to vector map <kyy> does not exist
> ERROR: Number of columns defined (3) does not match number of columns (9)
>       in input
> Of course all the other columns need to be defined as well.
> Or just use the auto-detector:
> v.in.ascii input=kyy.csv out=kyy skip=1 fs=, cat=3
> Importing points...
>  100%
> Populating table...
> Building topology for vector map <kyy>...
> Registering primitives...
> 23 primitives registered
> 23 vertices registered
> Building areas...
>  100%
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
>  100%
> Number of nodes: 23
> Number of primitives: 23
> Number of points: 23
> Number of lines: 0
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> v.in.ascii complete.
> > It seems a lot of people get this error (according to google...), but I
> > haven't seen a solution.
> I doubt this statement :)
> Hope this helps,
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110311/a7145371/attachment.html
