[GRASS-user] Buffer one side
kapo coulibaly kmcoulib at gmail.com
Sun Mar 13 13:53:55 EDT 2011
One solution I can see is to create the buffer first than split the
resulting buffer with the line you just buffered. I believe you can split a
polygon with a line by using the command v.overlay
On Sun, Mar 13, 2011 at 12:41 PM, leonidas <leonidas_liakos at yahoo.gr> wrote:
> I need to create a buffer only on one side (i.e. left side) of the lines of
> a
> shapefile? Is that possible?
> http://osgeo-org.1803224.n2.nabble.com/Buffer-one-side-tp6166623p6166623.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110313/636cb9c2/attachment.html
