[GRASS-user] Error while removing file
António Rocha antonio.rocha at deimos.com.pt
Wed Mar 16 10:16:39 EDT 2011
Just one small note:
If I try to remove tmpV I get this
Removing information about reclassed map from [new_clump10 at area] failed
Removing raster <myscript.tmpV1 at National>
And it's removed but then If I try to remove the new_clump10 I get:
[new_clump11 at area@area] is a base map for [myscript.tmpV1 at area]. Remove
forced.
Removing raster <new_clump11 at area>
misc: couldn't be removed
António Rocha wrote:
> Hi again :)
> Ok the main problem is that I'm using r.statistics with
> base=new_clump10 and cover= myscript.tmpV1
> If I try to remove new_clump I get:
> g.remove -f rast=new_clump10 at area
> [new_clump10 at area@area] is a base map for [myscript.tmpV1 at area].
> Remove forced.
> Removing raster <LULC_new_clump10 at National>
> So it wasn't removed. My question is:
> 1- Why it's repeating the Mapset information (new_clump10 at area@area)
> That is odd right? Maybe that is what is messing with the system
> Thanks
> Antonio
>>> Ok it has removed but when I try to write over that file I get
>>> errors like Permission DENIED.
>>> WHat can I do to fix this?
>> Ensure that all files and directories within the mapset directory are
>> owned by you, and have the necessary permissions (read and write for
>> files, read, write and execute for directories).
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5957 (20110316) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
