[GRASS-user] How To Identify db.copy Error?
Markus Neteler neteler at osgeo.org
Thu Mar 17 11:04:06 EDT 2011
On Thu, Mar 17, 2011 at 3:17 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>  One of the tables I'm copying from dbf to the postgres database threw an
> error:
> DBMI-Postgres driver error:
> Cannot create table:
> create table hydro_pointEvent ( cat integer, ComID integer, Permanent_
> varchar(40), EventDate varchar(10), ReachCode varchar(14), ReachSMDat
> varchar(10), ReachResol integer, FeatureCom integer, Feature_Pe varchar(40),
> FeatureCla integer, Source_Ori varchar(130), Source_Dat varchar(100),
> Source_Fea varchar(40), FeatureDet varchar(254), Measure double precision,
> Offset double precision, EventType integer )
> ERROR:  syntax error at or near "Offset"
> LINE 1: ...eatureDet varchar(254), Measure double precision, Offset dou...
> WARNING: Unable to create table <hydro_pointEvent>
> WARNING: Copy table failed
"Offset" is a reserved word in PostgreSQL:
"SQL Reserved Words Checker"
http://www.petefreitag.com/tools/sql_reserved_words_checker/?word=Offset
>  Is there a protocol I can use within GRASS to identify the syntax error?
Within GRASS no since it comes from (and depends on) the backend.
Above link seems to be useful.
Markus
