[GRASS-user] Re: r.proj -Segmentation fault
TimNorwey timmy_weyrer at live.at
Mon Mar 21 23:44:34 EDT 2011
> No problems here... the resulting map looks fine. My system:
> uname -a
> Linux north 2.6.33.7-desktop-2mnb #1 SMP Mon Sep 20 18:19:20 UTC 2010
> x86_64 x86_64 x86_64 GNU/Linux
Ok. Thank you very much for trying!
> Someone on Mac needs to try.. Or Tim, you need to run it through
> a debugger, see
> http://grass.osgeo.org/wiki/GRASS_Debugging#Using_GDB
> and post the full backtrace to a Trac ticket for analysis.
I´m currently working on a thesis to finish my Bachelor degree and I´m very
busy. As soon I have time, I will do that. I already took a look on it and
it seems to me a little bit complicated...
> PS: I'll send the reprojected map to you.
Thank you I got it. It´s perfect. :-)
Cheers Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-proj-Segmentation-fault-tp6181331p6194915.html
Sent from the Grass - Users mailing list archive at Nabble.com.
