[GRASS-user] Running a Pyhton Script on Mac (Mapcalc)
Johannes Radinger JRadinger at gmx.at
Tue Mar 22 06:02:54 EDT 2011
Hello,
I'd like to run a python script on my GRASS6.5 on MacOS.
I saved a *.py script for testing with following content on my desktop:
#!/usr/bin/python
#%Module
#% description: mapcalc test
#%End
#%option
#% key: upstream_shreve
#% type: string
#% gisprompt: new,cell,raster
#% description: output
#% required: yes
#%ends
#%option
#% key: upstream_part
#% type: string
#% gisprompt: old,cell,raster
#% description: input 1
#% required: yes
#%option
#% key: shreve
#% type: string
#% description: input 2
#% required: yes
#%end
import sys
import os
import atexit
import grass.script as grass
import grass.script.setup as gsetup
def cleanup():
    pass
def main():
    grass.mapcalc("$upstream_shreve = if(${upstream_part},${shreve})",
                   upstream_shreve = options['upstream_shreve'],
                   upstream_part = options['upstream_part'],
                   shreve = options['shreve'])
    return 0
if __name__ == "__main__":
    options, flags = grass.parser()
    atexit.register(cleanup)
    sys.exit(main())
All the needed files (upstream_part, shreve) are existing in the location and mapset that is open. Then I tried to execute File-->Launch Script and choose it. Then I just get back:
Launching script '/Users/Johannes Radinger/Desktop/mapcalc-test.py'...
(Tue Mar 22 10:57:15 2011)
(Tue Mar 22 10:57:15 2011) Command finished (0 sec)
and nothing happend and no map was created...
what is wrong with my script?
/johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
