[GRASS-user] gui wxPython2.5 and 2.6 problem on Mac, Path?
Johannes Radinger JRadinger at gmx.at
Wed Mar 23 09:21:53 EDT 2011
Hej...
because I had problems running a python script and the /usr/bin/env... I was looking which pyhton is in /usr/bin... there I found Python2.6 and Python2.5....It seems that they were probably in the wrong order in PATH i thought....in the Python2.6 folder in my Application ther was a file called "Update Shell Profile.command" and it was recommended in a forum to run that...
...so and now a big problem started: My wxpython gui isn't working anymore. wxpython, numpy and scipy are installed modules on my mac, but I get following error when I start GRASS GIS6.5:
Welcome to GRASS 6.5.svn (2011)
GRASS homepage:                          http://grass.osgeo.org/
This version running thru:               Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
Start the GUI with:                      g.gui wxpython
When ready to quit enter:                exit
GRASS 6.5.svn (Treene_location):~ > g.gui wxpython
Launching 'wxpython' GUI in the background, please wait ...
GRASS 6.5.svn (Treene_location):~ > Traceback (most recent call last):
  File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1630, in <module>
    sys.exit(main())
  File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1623, in main
    sys.exit(main())
    app = GMApp(workspaceFile)
  File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1522, in __init__
    wx.App.__init__(self, False)
  File "/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 7978, in __init__
    self._BootstrapApp()
  File "/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 7552, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/Applications/GRASS-6.5.app/Contents/MacOS/etc/wxpython/wxgui.py", line 1540, in OnInit
    timeout = 2000, parent = None, id = wx.ID_ANY)
TypeError: __init__() got an unexpected keyword argument 'extrastyle'
it seems that there is a problem that i have two versions of python and maybe GRASS can work only with python2.5... I tried a recompilation of GRASS, but still fail...
it is not a problem of GRASS itself but more of my set environemtal variables in the Path i think, but I don't know...
how can I check that, how can I set the Path correctly?
..how can I solve that problem?
/johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
