[GRASS-user] r.drain
Soeren Gebbert soerengebbert at googlemail.com
Thu Mar 24 07:47:56 EDT 2011
Hi Paolo,
try to use r.fill.dir on the elevation map with ~3 - 4 runs before you
use r.drain.
Best regards
Soeren
2011/3/24 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all.
> I'm testing r.drain, but I cannot get reasonable results over a dtm: the
> line produced is always much too short, stopping where it seems it
> should proceed. I exaggerated elevation (*100000), as suggested by the
> manpage, but results were only slightly better.
> Any suggestion?
> Thanks.
> http://www.faunalia.it/pc
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
