[GRASS-user] Running a Pyhton Script on Mac (Mapcalc)
Johannes Radinger JRadinger at gmx.at
Fri Mar 25 09:27:26 EDT 2011
Hello GRASS-people!!
I face a problem when I try to run mapcalculator in a pyhton script.
I attached a sample test script which i tried on the subset of the spearfish data set (http://grass.fbk.eu/sampledata/north_carolina/nc_basic_spm.tar.gz)
I just tried to multiply geology * elevation (just to try, in reality this wouldn't make sense, I know) and a new map should be created...but I fail and nothing is created. But the script itself can be loaded and I get to the interactive menu to choose the maps I want to process.
Is the script working on your GRASS? what is wrong with the script syntax?
cheers
/johannes
-------- Original-Nachricht --------
> Datum: Fri, 25 Mar 2011 12:45:18 +0100
> Von: "Johannes Radinger" <JRadinger at gmx.at>
> An: Nick Cahill <ndcahill at wisc.edu>, grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Running a Pyhton Script on Mac (Mapcalc)
> Thank you nick for the tipp with the line breaks!
> I opend the script with text wrangler and there were indeed
> mac line endings. So I saved it with unix line endings and
> now it seems to work. Maybe GRASS should be able to handle
> line endings from various platforms if that is possible...
> Now I get the menu for setting input and output for the script
> after launching it...seems to work...anyway I have to play around
> because no output is created at the moment from my script...hmmm?
> /johannes
> > Datum: Wed, 23 Mar 2011 05:06:51 -0500
> > Von: Nick Cahill <ndcahill at wisc.edu>
> > An: GRASS user list <grass-user at lists.osgeo.org>
> > I haven't run python scripts from within GRASS, but have found that they
> > won't run if the line breaks are not unix line breaks, rather than Mac
> or
> > Windows - which you'll get if you write the script in some applications.
> > BBEdit is a very good editor on the Mac and will run python scripts
> within
> > the editor. I think there's a free version too - text wrangler.
> > Nick Cahill
> > On Mar 23, 2011, at 2:29 AM, Johannes Radinger wrote:
> > > Am 23.03.2011 um 05:22 schrieb Glynn Clements:
> > >>> I'd like to run a python script on my GRASS6.5 on MacOS.
> > >>> I saved a *.py script for testing with following content on my
> > desktop:
> > >>> All the needed files (upstream_part, shreve) are existing in the
> > >>> location and mapset that is open. Then I tried to execute
> > >>> File-->Launch Script and choose it. Then I just get back:
> > >>> Launching script '/Users/Johannes
> Radinger/Desktop/mapcalc-test.py'...
> > >>> (Tue Mar 22 10:57:15 2011)
> > >>> /Users/Johannes Radinger/Desktop/mapcalc-test.py
> > >>> (Tue Mar 22 10:57:15 2011) Command finished (0 sec)
> > >>> and nothing happend and no map was created...
> > >>> what is wrong with my script?
> > >> Does the script have execute permission ("chmod +x ...")?
> > > The script has execute permission so far as I think, but anyway I ran
> > chmod +x on the file...
> > >> Does MacOSX have the Python interpreter at /usr/bin/python?
> > >> It's common practice for Python scripts to use:
> > >> 	#!/usr/bin/env python
> > > my first script included #!/usr/bin/env python, but it failed (error
> > message) it couldn't find python, thats why I googled  and found:
> > http://macosx.com/forums/unix-x11/46163-how-do-i-run-python-script.html
> > > that is why i used /usr/bin/python.
> > > I just got the tip in forum to check for the line-endings in the file,
> > they might cause the problem, so I will check that.
> > > But anyway, is there any other possible reason why I fail?
> > > Is there any Mac-User with Python-Script-Mapcalc experience?
> > >> which only requires that "python" is somewhere in $PATH, rather than
> > >> assuming a fixed location. The Python scripts in 7.0 use this
> > >> mechanism.
> > >> Glynn Clements <glynn at gclements.plus.com>
> > > _______________________________________________
> > > grass-user mailing list
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
Ihr GMX Postfach immer dabei: die kostenlose GMX Mail App für Android.
Komfortabel, sicher und schnell: www.gmx.de/android
Type: text/x-python-script
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110325/ee1d4110/testscript.bin
