[GRASS-user] Re: v.buffer problem (bug?)
Markus Metz markus.metz.giswork at googlemail.com
Sun Mar 27 14:31:04 EDT 2011
leonidas wrote:
> So, what should I do to run successfully the buffer?
You could compile 6.5 from source, then go to vector/v.buffer, run
make in that directory, optionally install grass and use v.buffer
instead of v.buffer2.
