[GRASS-user] error
    nsofina
    nsofina at gmx.de
    Mon May  2 09:25:47 EDT 2011
Hi everybody! <http://www.dict.cc/englisch-deutsch/Hi+everybody.html>
Some time ago I installed a new version of GRASS (GRASS 6.4.1 (2011) for
Windows. And now I can't start some modules that I created by myself. I
get the following error:
/Ungültiger Name der Vektorkarte <>. Darf nicht '.' oder 'NULL' enthalten./
/ERROR: Name der Ausgabe-Vektorkarte <> ist keine gültiger Kartenname./
I guess, this version of GRASS doesn't understand the definition of
temporary files (for example, $TMPVECT)
# Begin of the script
#g.message "Remove temporary files"
# g.remove vect=tmp_points
# g.remove vect=tmp
points_txt="C:/Work_directory/Algorithm/China/points.txt"
echo $GIS_OPT_INPUT1
echo $GIS_OPT_OUTPUT1
cats=`v.db.select map=$GIS_OPT_INPUT1 columns=cat | sed "s/cat//g"`
echo "cats =" $cats
echo "# Object Number DPC value" > $GIS_OPT_OUTPUT1
for i in $cats
do
echo "i =" $i
# if [ $i -lt 14 ] ;
# then
# continue
# fi
v.extract input=$GIS_OPT_INPUT1 output=$TMPVECT list=$i
v.to.points -v -i input=$TMPVECT output=$POINTS type=boundary,area dmax=5
v.out.ascii input=$POINTS output=$points_txt
I like the new GRASS version and try to adjust it to my needs.
Perhaps anybody has had to facethe same problem or knows a solution?
Thanks.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110502/b8b3bf17/attachment-0001.html
