[GRASS-user] SQLite driver errors: `Unable to open database'
Micha Silver micha at arava.co.il
Sun May 8 11:09:53 EDT 2011
On 05/08/2011 12:29 PM, Martin Landa wrote:
> Hi,
> 2011/5/8 Micha Silver<micha at arava.co.il>:
>> GRASS 6.4.0 (UTM36):~>  eval `g.gisenv`
>> GRASS 6.4.0 (UTM36):~>  db.connect driv=sqlite
>> database=$GISDBASE/$LOCATION_NAME/$MAPSET/geodata.db
>> GRASS 6.4.0 (UTM36):~>  db.connect -p
>> driver:sqlite
>> database:/home/micha/geodata/grass/UTM36/Israel/geodata.db
>> schema:
>> group:
> first of all, you don't need to run `g.gisenv`, just
> $ db.connect driv=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/geodata.db'
> is enough.
>> GRASS 6.4.0 (UTM36):~>  ll /home/micha/geodata/grass/UTM36/Israel/geodata.db
>> ls: cannot access /home/micha/geodata/grass/UTM36/Israel/geodata.db: No such
>> file or directory
> right, the database should be created when it's accessed.
> After running eg. `g.copy`
> $ eval `g.gisenv`
> $ file $GISDBASE/$LOCATION_NAME/$MAPSET/geodata.db
> /home/martin/grassdata/nc_spm_08/landa6/geodata.db: SQLite 3.x database
> The reported behaviour seems to be bug in winGRASS.
> Martin
Thanks for clarifying
Micha
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
