[GRASS-user] using "not so common characters" in Python Script
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Wed May 18 13:45:06 EDT 2011
Hi António
I usually start all my python scripts with the following two lines:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
The first line is nice for linux users. The second line ensures that I
can write non-ASCII characters in my code.
In your case, just add this second line to your script and make sure
it is either the first or second line of the script.
I recommend adding both lines to the top of the file, as a good practice.
If you'd like to know more just check out the link that the grass
error is giving you.
Cheers
2011/5/18 António Rocha <antonio.rocha at deimos.com.pt>:
> Greetings
> I would like to include some sentences with characters like á ã àó in my
> grass.message strings. It seems it's not possible Because I get this
>   grass.fatal(_('á'))
> I get:
>  File "C:/local/scripts/x.teste", line 41
> SyntaxError: Non-ASCII character '\xe1' in file
> C:/local/scripts/x.teste on line 41, but no encoding
> declared; see http://www.python.org/peps/pep-0263.html for
> details
> Is it possible?
> Thanks
> Antonio Rocha
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> database 6132 (20110518) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
___________________________ ___ __
Ricardo Garcia Silva
