[GRASS-user] Re: i.atcorr returns all NULL values
Juan Benavides Duque jbenavid at siu.edu
Fri May 27 18:34:05 EDT 2011
Skipped content of type multipart/alternative-------------- next part --------------
##TOAR VALUES FOR LANDSAT TM5 1986 BAND1 (
Fri May 27 16:56:10 2011)
r.univar map=COL_W1_1986_atcor_1 at LANDSAT3
(Fri May 27 16:56:16 2011) Command finished (6 sec)
(Fri May 27 16:56:30 2011)
r.univar map=COL_W1_1986_toar_1 at LANDSAT3
total null and non-null cells: 53428941
total null cells: 16389576
Of the non-null cells:
n: 37039365
minimum: -0.00298186
maximum: 0.331536
range: 0.334518
mean: 0.10724
mean of absolute values: 0.10724
standard deviation: 0.0530029
variance: 0.00280931
variation coefficient: 49.4247 %
sum: 3972086.9816170735
(Fri May 27 16:56:38 2011) Command finished (7 sec)
r.mask -r
PREFIX=COL_W1_1986_
g.region n=902700 s=695370 w=339300 e=571230 res=30
#CLOUD MASK PROCESS
#REMEMBER TO CHANGE THE FLAG FOR TM4 AQND TM5 (-t)
i.landsat.toar -s -t --overwrite input_prefix=${PREFIX} output_prefix=${PREFIX}toar_ metfile=L5009055_05519860908_MTL.txt sensor=tm5
ICNDF=icnd_W1_1986_
FILES="${PREFIX}toar_1  ${PREFIX}toar_2  ${PREFIX}toar_3 ${PREFIX}toar_4 ${PREFIX}toar_5
       ${PREFIX}toar_7"
for k in $FILES ; do
 i=`echo $k | sed 's+'${PREFIX}toar_'++g'| sed 's+ ++g'`
 echo "Processing ${PREFIX}toar_$i..."
i.atcorr -r -f -o --overwrite  input=$k elevation='RECLASS_SRTM3.1 at LANDSAT3' parameters=/home/dalevitt/grassdata/LANDSAT.RAW/LT50090551986251XXX04/${ICNDF}$i.txt output=${PREFIX}atcor_$i
 echo "ATMOSPHERIC  CORRECTION FILE  '${PREFIX}atcor_$i'"
done
