[GRASS-user] Redraw canvas of the Graphical Modeler does not work under Windows
Filipe Silva Dias filipesdias at gmail.com
Mon Nov 7 05:24:09 EST 2011
I tried with GRASS 6.5.svn and GRASS 7 svn and the window still doesnt
resize.
Thx
Filipe
On Sun, Nov 6, 2011 at 11:11 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2011/11/6 Filipe Silva Dias <filipesdias at gmail.com>:
> > I built a model with a lot of actions and at some point I moved one of
> the
> > actions out of the visible canvas. I pressed Redraw Model Canvas to be
> able
> > to select it and move it closer to the others,but the window didnt
> resize. I
> > tried to use the scroll bars but I couldnt. Now I cant click or select
> the
> > action that is "out of the visible" window.
> > Is there something wrong with the graphical modeler window or am I
> missing
> > something?
> > Im using GRASS 6.4.2 RC1 and GRASS 7 svn under Windows 7 64 bit.  Under
> > LInux Ubuntu everything works fine.
> > (Also: If I select parametrize in any action and the press Run, the model
> > doesnt run. Nothing happens when I press it)
> there were quite a lot of changes in the modeler since 6.4.2RC1, could
> you try GRASS 6.5 [1]?
> Martin
> [1] http://wingrass.fsv.cvut.cz/grass65/
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111107/858b3187/attachment.html
