[GRASS-user] Main difference between r.category and r.reclass
    Moritz Lennert
    mlennert at club.worldonline.be
    Sat Nov 12 05:32:14 EST 2011
On 10/11/11 23:47, Luisa Peña wrote:
> Greetings
> I have a table of values to which I want to define a text label. Which
> function shall I use? r.category and r.reclass? because both seem to be
> used for the same in this case. My case is:
> 1 Water
> 2 Forest
> 3 Urban
> 4 Ocean
> 5 Marsh
> 6 Agriculture
If all you want to do is add text labels to your categories, then
r.category is your friend. You can use r.reclass to the same effect, but
it is meant to be used for changing category values through
reclassification.
Moritz
