[GRASS-user] Problems while running d.out.file
António Rocha
antonio.rocha at deimos.com.pt
Wed Nov 16 05:55:09 EST 2011
Hi Martin
About that functionality. d.out.file allows me to define size of output
image which is something that I need. WHen I try to do that with the
functionality that you mention (e.g. with smaller H and W) I get the
error I reported here
(http://lists.osgeo.org/pipermail/grass-user/2011-November/062577.html).
Michael Barton suggested me to use this function.
I really need to produce output maps with a specific size and with
image+scale bar. and when I set HxW I loose Scalebar in my output image.
Antonio
Martin Landa wrote:
> Hi,
> 2011/11/16 António Rocha <antonio.rocha at deimos.com.pt>:
>> I'm trying to run d.out.file to produce a PNG file with a defined size (and
>> others) but I get the following error:
>> ERROR: You must select a display monitor.
>> SInce I'm running from WxPython interface how can I do that?
> you need to start some monitor, eg. `d.mon start=PNG` and then stop
> it. Why are you not using functionality available from wxGUI Map
> Display [1]?
> Martin
> [1] http://www.youtube.com/watch?v=PY8aytvfQqA&feature=player_embedded
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6634 (20111116) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
