[GRASS-user] GRASS 7 error code 9
Markus Metz markus.metz.giswork at googlemail.com
Sun Nov 20 06:32:26 EST 2011
Glynn Clements wrote:
> AFAICT, r.watershed requires far more memory than just the size of the
> underlying raster data. It's possible that it isn't interpreting the
> memory= parameter correctly.
Yes, there was an error in the distribution of memory over the various
temporary data structures, fixed in r49314. r.watershed.seg should now
use usually a bit less than memory=X MB and only in special cases get
close to the allowed limit.
Markus M
