[GRASS-user] getting error msg "g.echo.exe not found" to compile source code
Johannes Radinger JRadinger at gmx.at
Thu Nov 24 04:33:01 EST 2011
Hello,
How did you install the new make 3.81?
as I had the same problem some weeks ago,
here what needs to be done (at least in my case):
1) It is really important to follow the wiki (compile_on_windows)!
2) Download the latest make program compliant with the OSGeo4W framework from  here. (download only from here and not any installer or
anything...)
3) Unzip the folder and copy its subfolder contents into the corresponding subfolders of c:\osgeo4w\apps\msys. This step is really important!
4) Close and re-open msys
5) make -version
/Johannes
-------- Original-Nachricht --------
> Datum: Thu, 24 Nov 2011 09:01:01 +0100
> Von: Markus Neteler <neteler at osgeo.org>
> An: Sandip Maity <sandip.stesalit at gmail.com>
> CC: GRASS user list <grass-user at lists.osgeo.org>
> Betreff: Re: [GRASS-user] getting error msg "g.echo.exe not found" to compile	source code
> On Thu, Nov 24, 2011 at 6:43 AM, Sandip Maity <sandip.stesalit at gmail.com>
> wrote:
> > I downloaded make 3.81.
> > But after installation make is 3.79.1
> > Please suggest any idea.
> Please contact the OSGeo4W list - there are more people having this
> problem. Maybe, if more people are asking, then it will be recognized
> as a problem?
> Sorry for no better answer,
> Markus
> PS: Please note that there is the precompiled version
> http://wingrass.fsv.cvut.cz/grass70/osgeo4w/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
