[GRASS-user] LiDAR LAS import
Daniel Victoria daniel.victoria at gmail.com
Fri Nov 25 07:05:47 EST 2011
I removed the ubuntu Liblass and compiled the latest version by hand.
Grass compilation went fine but unfortunatelly I still can't test it
because I'm having some other problems. Location Wizard is not opening
and when I try to open v.in.lidar I get:
python: can't open file
'/home/daniel/grass_src/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gui_modules/menuform.py':
[Errno 2] No such file or directory
Something probabli went wrong during compilation...
Cheers
Daniel
On Fri, Nov 25, 2011 at 6:17 AM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> Daniel Victoria wrote:
>> Hi Rebecca et al.,
>> I'm having the same problem. Installed liblas using ubuntu packages
>> and when I run configure I get that it's unable to locate libLAS
>> library.
>> daniel at daniel-desktop:/usr/lib$ liblas-config --libs
>> -L/usr/lib -lgeotiff -L/usr/lib -lgdal1.6.0
>> daniel at daniel-desktop:/usr/lib$ liblas-config --includes
>> -I/usr/include/geotiff -I/usr/include/gdal
>> Has anyone figured out what is going on?
> I think I got it. LibLAS 1.6.1 and 1.7.0: liblas-config --libs
> -L/usr/local/lib -llas -llas_c -L/usr/lib64
> /usr/lib64/libboost_program_options-mt.so
> /usr/lib64/libboost_thread-mt.so /usr/local/lib64/libgdal.so
> /usr/local/lib64/libgeotiff.so /usr/lib64/libtiff.so
> /usr/local/lib64/liblaszip.so
> The crucial difference is -llas -llas_c which is missing for libLAS 1.2
> Maybe this (-llas -llas_c) should be always included by configure for libLAS ?
> Markus M
>> Thanks
>> Daniel
>> On Fri, Jul 29, 2011 at 8:10 AM, Rebecca Bennett <rabennett at ymail.com> wrote:
>>> sorry for the delayed reply - (windoze day yesterday)
>>>>Hmm. Is lasinfo --help working?
>>> Yes. wont paste the output here but it is as expected.
>>> Thanks,
>>> Rebecca
>>> ________________________________
>>> From: Markus Metz <markus.metz.giswork at googlemail.com>
>>> To: Rebecca Bennett <rabennett at ymail.com>
>>> Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
>>> Sent: Wednesday, 27 July 2011, 18:01
>>> Subject: Re: [GRASS-user] LiDAR LAS import
>>> On Wed, Jul 27, 2011 at 3:28 PM, Rebecca Bennett <rabennett at ymail.com>
>>> wrote:
>>>> sure -
>>>> checking whether to use libLAS... yes
>>>> checking for liblas-config... /usr/bin/liblas-config
>>>> configure: error: *** Unable to locate libLAS library.
>>>> I have the packages liblas1, liblas-dev, lib-las-bin and python-liblas
>>>> installed through synaptic and am wondering if there is a libraty package
>>>> missing?
>>> What does
>>> and
>>> say?
>>>> Sent: Wednesday, 27 July 2011, 13:16
>>>> Rebecca Bennett wrote:
>>>>> Hello,
>>>>> Just trying to install GRASS 7 on Ubuntu 10.04 to try out the las import
>>>>> functions but I'm getting error messages during the configure that it is
>>>>> unable to find the liblas library, however the liblas library is
>>>>> installed
>>>>> in usr/bin/lib/ so I'm a bit puzzled...
>>>> Can you post the exact error message? Also, liblas support will only
>>>> be available if liblas-config exists.
>>>> Markus M
>>>>> Did anyone else get stuck here or am I missing something obvious?
>>>>> Thanks for reading,
>>>>> Rebecca
>>>>> To: Hamish <hamish_b at yahoo.com>
>>>>> Cc: grass-user <grass-user at lists.osgeo.org>; GRASS developers list
>>>>> <grass-dev at lists.osgeo.org>
>>>>> Sent: Wednesday, 25 May 2011, 12:48
>>>>> On Wed, May 25, 2011 at 12:16 PM, Hamish <hamish_b at yahoo.com> wrote:
>>>>>> Markus Metz wrote:
>>>>>>> Hi all,
>>>>>>> GRASS 7 has a new module v.in.lidar for importing LiDAR LAS files
>>>>>>> (*.las or *.laz). The LAS file format is commonly used for storing
>>>>>>> LiDAR point clouds, but is unfortunately not supported by OGR.
>>>>>>> v.in.lidar uses the libLAS library [0] and is only compiled if the
>>>>>>> libLAS library is present.
>>>>>>> I chose to use the library instead of writing a custom LAS reading
>>>>>>> interface because the current LAS library version 1.6.1 is stable,
>>>>>>> supports LAS file versions 1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, each of
>>>>>>> which can store LiDAR points in up to 5 different point formats. The
>>>>>>> user and the interface do not need to know the file version and point
>>>>>>> format of a given file, all that is conveniently handled by the libLAS
>>>>>>> library in the background. The library has Large File Support (LFS)
>>>>>>> and is well tested on different platforms, also with different
>>>>>>> endian-ness. This functionality is not that easy to replicate.
>>>>>>> You will need to get the libLAS library and configure GRASS 7 with
>>>>>>> --with-liblas in order to have the module available. Please test!
>>>>>>> Markus M
>>>>>>> [0] http://www.liblas.org
>>>>>> neat! any time trials to say how much faster it is than piping
>>>>>>  las2txt | v.in.ascii
>>>>> Note that las2txt does NOT apply scale and offset to x,y,z, this would
>>>>> need to be done afterwards in order to obtain correct coordinates.
>>>>> Therefore the output of las2txt | v.in.ascii with the sample las file
>>>>> I used is incorrect.
>>>>> I discovered a bug in v.in.ascii: from a point file with | as field
>>>>> separator like
>>>>> 1|2|3||5|6
>>>>> only the first 3 columns will be imported because column 4 is empty
>>>>> which means that columns 5 and 6 are skipped.
>>>>> v.in.lidar is a notch faster than las2txt | v.in.ascii. And easier to
>>>>> use...
>>>>> Speed comparisons:
>>>>> # sample las file with 1,287,775 points
>>>>> # with table and topology
>>>>> time las2txt -i points.las --stdout --parse xyztinrcCpedRGBau
>>>>> --delimiter "|" | v.in.ascii in=- out=points_ascii -z x=1 y=2 z=3 --o
>>>>> real    6m34.430s
>>>>> user    4m57.530s
>>>>> sys    2m3.693s
>>>>> time v.in.lidar in=points.las out=points_las -o --o
>>>>> real    6m13.823s
>>>>> user    4m32.061s
>>>>> sys    2m1.068s
>>>>> # without table, with topology
>>>>> time las2txt -i points.las --stdout --parse xyz --delimiter "|" |
>>>>> v.in.ascii in=- out=points_ascii -zt x=1 y=2 z=3 --o
>>>>> real    1m53.578s
>>>>> user    1m47.032s
>>>>> sys    0m9.238s
>>>>> time v.in.lidar in=points.las out=points_las -ot --o
>>>>> real    1m44.876s
>>>>> user    1m34.450s
>>>>> sys    0m8.488s
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
