[GRASS-user] Runtime error! / Program: C:\Osgeo4w\bin\python.exe
Sandip Maity sandip.stesalit at gmail.com
Tue Nov 29 02:57:03 EST 2011
Hi johannes and all,
According to your suggestion, I uninstall the libtiff- 4.0.0dev 91 and
install libtiff 90. Also I have update make directory according to your
direction.
Make -version showing 3.81.
But Still same error is coming.
Please reply sap.
Regards.
Sandip
On Mon, Nov 28, 2011 at 7:23 PM, Johannes Radinger <JRadinger at gmx.at> wrote:
> Hi,
> Maybe that is causing the problem (as it did in my case!)
> Via the advanced setup you can you can choose 4.0.0dev-90.
> This works in my case. But you have to be careful then
> with the make (the one you installed manually) this can be
> updated and overwritten by the osgeo4w setup with the old version
> 3.7 again.
> In that case you have to set to libtiff 4.0.0dev-90 and after that you
> have to copy again the new GNU make files (v3.81) into the directory
> (as you already did according to the wiki)
> Maybe we have to make that clearer in the wiki or do changes in
> the osgeo4w setup to overcome the complicated and somehow interfering
> installation of make3.81 and libtiff 4.0.0dev-90.
> /Johannes
> -------- Original-Nachricht --------
> > Datum: Mon, 28 Nov 2011 17:54:07 +0530
> > Von: Sandip Maity <sandip.stesalit at gmail.com>
> > An: Johannes Radinger <JRadinger at gmx.at>
> > CC: grass-user at lists.osgeo.org
> > Betreff: Re: [GRASS-user] Runtime error! / Program:
> C:\\Osgeo4w\\bin\\python.exe
> > Dear Johannes,
> > I have installed libtiff 4.0.0dev-91 via osgeo4w setup.
> > Please suggest the way.
> > Regards.
> > Sandip
> > On Mon, Nov 28, 2011 at 4:42 PM, Johannes Radinger <JRadinger at gmx.at>
> > wrote:
> > > Hello,
> > > after a quick google-search: It seems an Error related to
> > > the MSVCR80.DLL. AFAIK this .dll comes
> > > with the libtiff via the osgeo4w setup. Which version of
> > > libtiff do you have installed (check in the osgeo4w advanced
> > > setup)?
> > > But maybe some others have any other idea!?
> > > /Johannes
> > > > Datum: Mon, 28 Nov 2011 15:49:14 +0530
> > > > An: grass-user at lists.osgeo.org
> > > > Betreff: [GRASS-user] Runtime error! / Program:
> > > > Dear friend,
> > > > I am compiling and installing grass on windows.
> > > > But getting error as follows.
> > > > Runtime error!
> > > > R6034
> > > > An application has made an attempt to load the c runtime library
> > > > incorrectly.
> > > > Please help me how can i resolve the issues.
> > > > regards.
> > > > Sandip
> > > NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
> > > Jetzt informieren: http://www.gmx.net/de/go/freephone
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111129/7a1d3b16/attachment.html
