[GRASS-user] upslope contributing areas
Francesco Mirabella mirabell at unipg.it
Thu Oct 13 03:04:26 EDT 2011
Hello,
and thanks for your fast replies,
yes, the final result which I'd like to get is a river profile along
which the values of the upslope contributing areas can be plotted on a
separate y axis.
In order to get this I suppose I should be able to "cat
river_long_profile_ascii | r.profile a_raster_map_containing_the
upslope_areas" which can provide values in square meters or square km or
whatever.
Do you know if such a raster map can be obtained from a dem?
Francesco
Rainer M Krug wrote:
> It depends on what the OP was looking for - it sounds to me that he is
> looking for a kind of "dynamic" approach, where one can determine the
> upslope drainage area for an arbitrary location. Unfortunately, I don't
> have a solution, but would be quite interested in the answer.
> Cheers,
> Rainer
> On Thu, Oct 13, 2011 at 8:36 AM, Johannes Radinger <jradinger at gmx.at
> <mailto:jradinger at gmx.at>> wrote:
>     Hello Francesco,
>     you could use something like the AddOn r.stream.basin
>     (http://grass.osgeo.org/wiki/R.stream.*)
>     to delineate the basins. Every basin gets a unique number.
>     Afterwards you can just query how
>     many cells do have a certain number.
>     best regards!
>     Am 13.10.2011 <tel:13.10.2011> um 08:20 schrieb Francesco Mirabella:
>      > Hi list,
>      > does anyone know if there is a way to compute the upslope
>     drainage contributing areas along a stream?
>      > thanks for your help!
>      > Francesco
>      > _______________________________________________
>      > grass-user mailing list
>      > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>      > http://lists.osgeo.org/mailman/listinfo/grass-user
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel :       +33 - (0)9 53 10 27 44
> Cell:       +33 - (0)6 85 62 59 98
> Fax (F):       +33 - (0)9 58 10 27 44
> Fax (D):    +49 - (0)3 21 21 25 22 44
> email:      Rainer at krugs.de <mailto:Rainer at krugs.de>
> Skype:      RMkrug
