[GRASS-user] Problem after Installing OS X 10.7
Kurt Springs ferret_bard at mac.com
Sat Sep 10 19:21:05 EDT 2011
Hi Folks,
I finally installed OS X 10.7.1.  Because I had a corruption with Java I did a clean install.  I’ve been gradually loading things back in.  I ran into trouble when I got to GRASS.  I have William Kyngebure’s 6.4.1-5.  I launched it for the first time and got the following in Terminal:
____
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS 6.4.1 (2011)
GRASS homepage:                          http://grass.osgeo.org/
This version running thru:               Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
GRASS 6.4.1 (NH-State_Plane):~ > ERROR: MAPSET PERMANENT - permission denied
2011-09-10 18:49:22.524 Python[1232:e0f] CFURLCreateWithString was passed this invalid URL string: '/System/Library/CoreServices/CommonCocoaPanels.bundle' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
GRASS 6.4.1 (NH-State_Plane):~ > exit
exit
/Applications/GRASS-6.4.app/Contents/MacOS/etc/Init.sh: line 899:  1232 Killed: 9               "$GRASS_PYTHON" "$GISBASE/etc/wxpython/wxgui.py"
Closing monitors ...
Closing open gis.m sessions.....
Cleaning up temporary files ...
Done.
Goodbye from GRASS GIS
logout
[Process completed]
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Last login: Sat Sep 10 18:48:20 on ttys000
kurt-springss-mac-pro:~ kurtsprings$ '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
2011-09-10 19:01:52.382 osascript[1570:707] Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types:  dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found.  Did find:
	/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper
osascript: OpenScripting.framework - scripting addition "/Library/ScriptingAdditions/Adobe Unit Types.osax" declares no loadable handlers.
Python 2.6.6 found.
Starting GRASS ...
2011-09-10 19:01:56.428 Python[1602:e0f] CFURLCreateWithString was passed this invalid URL string: '/System/Library/CoreServices/CommonCocoaPanels.bundle' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
____
I’ve loaded the frame works.  Permissions were an issue as I moved things From time machine to a User with an (old) tag and ported them to my new user file.  I think  that was solved.  Everything I’ve checked gives my new User Read and Write permission.
Any thoughts.
Kurt
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110910/004a6b9e/attachment.html
