[GRASS-user] Import a catalog of ascii *.arc files and merge to a raster
Markus Metz markus.metz.giswork at googlemail.com
Sun Apr 1 12:42:48 EDT 2012
Lars Forseth wrote:
> Thanks Daniel.
> But no, I was not able to make your suggestion work; it complains that it
> dos not know the command 'For'...
In Linux shell and msys this must be lowercase, i.e.
for i in *.arc
do r.in.arc $i <output name here>
done
or
for i in *.arc
do r.in.arc in=$i out=`basename $i .arc`
done
followed by something like
raster_list=`g.mlist type=rast pat=<insert search pattern here> sep=comma`
g.region -p rast=$raster_list
r.patch in=$raster_list out=<output name here>
HTH,
Markus M
> Regards larsf
> Den 01. april 2012 16:01, skrev Daniel Victoria:
> I believe there is a batch import function in the gui ( I'm not in front of
> my computer now). If not, you can write a for loop in the command line to
> import all files.
> In Linux shell it's something like
> For i in *.arc
> Do r.in.arc $i <output name here>
> Done
> Daniel
> On Apr 1, 2012 10:13 AM, "Lars Forseth" <lars.forseth at ntebb.no> wrote:
>> Hi!
>> I want to import a set (20) of ESRI ASCII raster files in a catalog, and
>> merge them to a single GRASS raster dataset.
>> How do I do that? (Yes I can import each file, and then merge (r.patch),
>> but..)
>> Regards larsf
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
