[GRASS-user] r.stream.extract Syntax Problem
Margherita Di Leo diregola at gmail.com
Fri Apr 6 11:49:31 EDT 2012
Rich,
On Fri, Apr 6, 2012 at 5:41 PM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
> On Fri, 6 Apr 2012, Margherita Di Leo wrote:
>  AFAIK (but surely Markus Metz will give an insight) r.stream.extract must
>> run with flow accumulation produced by r.watershed. In order to use a
>> weighted flow accumulation, I would produce it using the r.watershed
>> command with the option "flow", instead of mapcalc.
> madi,
>  As I wrote, I've been following the example on the manual page, so
> # calculate flow accumulation
> r.watershed ele=elevation.10m at PERMANENT acc=elevation.10m.acc -f
> I've run r.watershed elev=dem10m.avg accum=dem10m.acc -f
I meant something like:
r.watershed ele=elevation.10m at PERMANENT acc=elevation.10m.weight_acc
flow=weight -f
> Rich
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
Ing. Margherita Di Leo, Ph.D.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120406/9be0b9fd/attachment.html
