[GRASS-user] Vector not getting imported in GRASS v7.0 latest svn.
Markus Metz markus.metz.giswork at googlemail.com
Wed Apr 18 05:03:26 EDT 2012
On Wed, Apr 18, 2012 at 10:26 AM, Pankaj Kr Sharma <pkscwc at gmail.com> wrote:
> After completion of the import process, following error message is displayed
> Command 'd.vect map=%@%' failed
> Details: The bounding box of the map is outside the current
> region, nothing drawn
> % is to indicate that I tried several maps.
> Points only layers are getting imported but polygon layer have problems.
> I have checked the region, and it is correctly set.
Have you tried to zoom to the selected map and/or zoom to the current
computational region?
Can you provide the output of v.info and g.region? Ideally, can you
also provide a (link to a) sample polygon vector for import?
Markus M
