[GRASS-user] r.watershed: output basin map
Rich Shepard rshepard at appl-ecosys.com
Wed Apr 18 18:48:34 EDT 2012
   The attached pdf shows the basin map output by r.watershed based on a 10m
DEM and a threshold of 150000. The NHD level 6 subbasins are outlined in
black and the 1:24K NHD streams are in blue.
   The small white areas at the bottom left and center right appear to be
external to defined sub-basins. But I don't know how to interpret the larger
white areas with streams in them (center and top). The top margin is an
international boundary so I can understand not being able to completely
define sub-basins across that boundary since the DEM doesn't reach that far
north, but it's not consistently white.
   Please help me interpret the white areas with vector streams.
TIA,
Rich
Type: application/pdf
Desc:
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20120418/beb8bc6c/ebeco-basins-0001.pdf
