[GRASS-user] internal buffer of polygon
Markus Neteler neteler at osgeo.org
Thu Apr 19 12:17:59 EDT 2012
Hi all,
does anyone have a new(er) trick for negative vector buffers (in GRASS 7)?
thanks
Markus
On Thu, Oct 29, 2009 at 4:59 PM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> Hi Maning,
> Sometimes I have the same issue, but I don't solve this on vector.
> Just supose you have a map where 1 is your raster-based-polygon
> and NULL is outside of polygon. You can use r.mapcalc to
> invert it, in the maner that 1 come to be your non-polygon, and
> NULL your polygon. So you can run r.buffer with positive value
> and at the end may be you need to do some kind of crossing
> between original and output maps.
> Bests.
> miltinho
> 2009/10/29 maning sambale <emmanuel.sambale at gmail.com>
>> I tried using a negative values as
>> buffer=-3000 in v.buffer but it doesn't give me internal buffer in a
>> polygon layer.
>> Any hints?
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
