[GRASS-user] r.sun and XY locations
    christian.braun at tudor.lu
    Thu Aug  9 00:54:32 PDT 2012
Hi Daniel,
it's clear to me that r.sun needs some sort of spatial reference.
I thought that is why I can provide latitude and longitude grids as input
for the very special case of an XY location. Isn't it like that?
cheers
Christian
_________________________________________
Christian Braun,
R+D Engineer
Environmental Modelling, Geocomputation
Tel: +352- 425991-6608
Mobil: +49-179-6845896
Mail: christian.braun at tudor.lu
Resource Centre for Environmental Technologies,
Public Research Centre Henri Tudor,
Technoport Schlassgoart,
66 rue de Luxembourg,
P.O. BOX 144,
L-4002 Esch-sur-Alzette, Luxembourg
To:     Christian Braun <Christian.Braun at tudor.lu>,
Cc:     grass-user at lists.osgeo.org
Date:   08/08/2012 17:44
Subject:        Re: [GRASS-user] r.sun and XY locations
Hi Christian,
Determining the position of the sun relative to a given pixel requires
knowing the pixel's latitude at the very least. That's why using r.sun in
an XY location won't work. r.sun definitely needs a geographic location to
work with - otherwise it doesn't know which way is north and south and
where the sun's at at a given time of day or year.
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
2012/8/8 Christian Braun <Christian.Braun at tudor.lu>
Dear all,
I want to create a WPS module which is calculating solar irradiance. As
WPS architecture I have to use PyWPS which is creating a XY-location and
mapsets on the fly to process the data.
What is the current status of running r.sun in a XY location? On a testing
machine I got back an error message [1] while providing latitude and
longtiude grids to the r.sun command [2]. Is it feasible at all?
I am aware of the setting in PyWPS to have the GRASS processing done in a
predefined GRASS location, but this is not an option because of how the
WPS should work.
Greetings from Luxembourg,
Christian
[1]
WARNING: <PROJ_INFO> file not found for location <XY>
ERROR: Can't get projection info of current location
[2]
r.sun -s elevin=ro_dsm latin=ro_latitude longin=ro_longitude lin=3
alb=0.17 beam_rad=ro_irra_B_hc diff_rad=ro_irra_D_hc glob_rad=ro_irra_G_hc
day=180 step=1
Christian Braun
R+D Engineer
P.O. BOX 144,
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120809/3ef8554b/attachment.html>
