[GRASS-user] interpolation from massive vector point input
Margherita Di Leo diregola at gmail.com
Mon Aug 27 06:15:43 PDT 2012
Hi Johannes,
On Mon, Aug 27, 2012 at 11:58 AM, Johannes Radinger <
johannesradinger at gmail.com> wrote:
> Hi,
> I get a text file from a hydromorphological model which includes
> an massive amount of geographical points with attributes
> (velocity,depth,..),
> which I input using v.in.ascii (around 120000 points).
> The points are located in a river (20 m widht) in a resolution of
> appr. 20x20 cm,
> but this is not fixed and depending on their location within in the river
> (points in the outer bends show rougher resolution then points in the
> inner bends).
> So these points are not regularly (in the sense of raster map) distributed.
> Anyway I want to generate a raster surface (resolution = appr. 0.25)
> from the vector points attributes, e.g  a surface of velocity and one
> for depth.
> Additionally to the vector points there is a line vector indicating
> the shore line
> of the river (depth=0 and velocity = 0).
> Now I am looking for a method for interpolation of these points. I
> found v.surf.icw
> which would take into account that there is a shoreline which is not
> overflown
> by the water (interpolates within the river). But it is not recommended
> for such
> massive data point input. Is there any other recommendable way fur such
> a purpose (considering the shore line and that there is 0 velocity and
> 0 depth on land?
> Any suggestions are welcome!
Consider also v.surf.rst
http://grass.osgeo.org/grass70/manuals/html70_user/v.surf.rst.html
See also http://grass.osgeo.org/wiki/RST_Spline_Surfaces
ciao
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120827/b275ff55/attachment.html>
