[GRASS-user] Spectral Unmixing
Mohammed Rashad mohammedrashadkm at gmail.com
Fri Dec 7 23:16:50 PST 2012
Hi Thomas,
I had ported spectral unmixing to grass7. Myself and Markus had tested it
several times on both G6 and G7 and updated it every time.
The problem is because of g2c.h which is not used by gcc4+. and g2c.h
headers are included in lapack wrap code of gmath lib.
The error he said about __g77_integer is mentioned here
https://bugs.launchpad.net/ubuntu/+source/gcc-3.4/+bug/61623
which says gcc-3.4
On Sat, Dec 8, 2012 at 12:33 PM, Thomas Becker <thomasgeo at gmx.de> wrote:
> Hi,
> there was recently some question about spectral unmixing here in the list.
> If you didn't modify the source code of the unmixing model to fit Grass 7
> it won't work. Spectral unmixing was written by Markus as part of his
> diploma thesis, is now some years old and is based on Grass 5.something, if
> I'm not wrong.
> Would be great if you can get it to work in Grass 7.x! Seems to me there
> is quite some interest in this module.
> \T
> On 08.12.2012, at 05:04, 王德辉 <dehuiw at gig.ac.cn> wrote:
> > Hi all!
> > compilation error in ubuntu12.10 x64
> > GRASS 7.0.svn
> (nc_spm_08):/usr/local/grass-addons/grass7/imagery/i.spec.unmix > sudo make
> MODULE_TOPDIR=/usr/local/grass-7.0.svn
> > gcc  -g -O2   -I/usr/local/grass-7.0.svn/include
> -I/usr/local/grass-7.0.svn/include  -D_FILE_OFFSET_BITS=64
>  -DPACKAGE=\""grassmods"\"   -I/usr/local/grass-7.0.svn/include
> -I/usr/local/grass-7.0.svn/include -o
> OBJ.x86_64-unknown-linux-gnu/la_extra.o -c la_extra.c
> > In file included from /usr/local/grass-7.0.svn/include/grass/la.h:34:0,
> >                  from la_extra.c:12:
> > /usr/include/g2c.h:21:1: error: unknown type name ‘__g77_integer’
> > /usr/include/g2c.h:22:1: error: unknown type name ‘__g77_uinteger’
> > /usr/include/g2c.h:29:1: error: unknown type name ‘__g77_integer’
> > /usr/include/g2c.h:33:1: error: unknown type name ‘__g77_longint’
> > /usr/include/g2c.h:34:1: error: unknown type name ‘__g77_ulongint’
> > /usr/include/g2c.h:55:1: error: unknown type name ‘__g77_integer’
> > /usr/include/g2c.h:56:1: error: unknown type name ‘__g77_integer’
> > /usr/include/g2c.h:57:1: error: unknown type name ‘__g77_integer’
> > la_extra.c: In function ‘G_matvect_get_column2’:
> > la_extra.c:22:2: warning: format not a string literal and no format
> arguments [-Wformat-security]
> > la_extra.c:27:2: warning: format not a string literal and no format
> > la_extra.c:32:2: warning: format not a string literal and no format
> > la_extra.c: In function ‘mv_mlt’:
> > la_extra.c:257:9: warning: assignment from incompatible pointer type
> [enabled by default]
> > la_extra.c: In function ‘G_vector_product’:
> > la_extra.c:396:2: warning: format not a string literal and no format
> > la_extra.c:401:2: warning: format not a string literal and no format
> > la_extra.c:406:2: warning: format not a string literal and no format
> > la_extra.c:411:2: warning: format not a string literal and no format
> > la_extra.c:417:2: warning: format not a string literal and no format
> > la_extra.c:423:2: warning: format not a string literal and no format
> > la_extra.c: In function ‘G_matrix_read2’:
> > la_extra.c:470:2: warning: format not a string literal and no format
> > la_extra.c:480:6: warning: format not a string literal and no format
> > la_extra.c:486:3: warning: format not a string literal and no format
> > make: *** [OBJ.x86_64-unknown-linux-gnu/la_extra.o] Error 1
> > Thanks!
> > dehui
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121208/9061c84b/attachment-0001.html>
