[GRASS-user] r.drain problem when flow reach the border
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Wed Dec 26 13:01:21 PST 2012
Hi Mohamed and Markus
Mohamed, thanks for your reply, I will wait for a solution within GRASS :-)
Markus, thanks for your reply,. Sorry  but I disagree a tiny bit,
because is expected that between a source and target I will find a
solution with the Least Cost path. Do you think that is there any
situation where a least cost between source and target will not be
found? Maybe if other software provide the soluction, although is not
the bestest option, I prefere receive one complete output than a
broken one.
Happy new year!
miltinho
2012/12/23, Markus Metz <markus.metz.giswork at gmail.com>:
> On Sun, Dec 23, 2012 at 7:07 PM, Milton Cezar Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
>> Dear all,
>> I am running a least cost path analysis combining r.cost and r.drain.
>> But on some cases, when the least cost path between source and target
>> reach the border of my map, r.drain stop on that position, and target
>> point isn´t reached.
> This is correct because at the borders, the direction can not be
> determined, the path could lead out of the current region, you can not
> tell.
> Running on other softwares the algorithms the
>> source and target is connected using edges without problem.
> If in doubt, I would call it a bug in that other software.
>> Any hint are welcome.
> Try to expand the current region
> Markus M
Miltinho - mcr at rc.unesp.br
Laboratório de Ecologia Espacial e Conservação - LEEC
Depto de Ecologia - UNESP - Rio Claro
Av. 24A, 1515- Bela Vista
13506-900 Rio Claro, SP, Brasil
Fone: +55 19 3526-9647 (office)  19 3526-9680 (lab)
Cel: 19 9853-3220 / 19 9853-5430
Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
PG ECO & BIODIV http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
