[GRASS-user] r.drain problem when flow reach the border
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Sun Dec 30 11:59:50 PST 2012
Hi Rashad
I tested with the trunk svn, but apparently it still not worked to me.
Are you able to test with my datased?
https://www.yousendit.com/download/UW16RE9zTkxlM1JBSXNUQw
Thanks!
miltinho
2012/12/27, Mohammed Rashad <mohammedrashadkm at gmail.com>:
> Hi Milton,
> I think this fix will solve the problem[0]. For elevation data there might
> be cases where no path exists ie, only single pixel is the selected path. I
> had tested it by myself and it worked.
> Please apply the patch and let me know.
> If any problem comes in compilation or doing r.drain let me know. It will
> be great if you can share the test data you are using in case not working
> after applying the patch
> [0] http://trac.osgeo.org/grass/attachment/ticket/1840/r.drain.diff
> [1] http://trac.osgeo.org/grass/attachment/ticket/1840/drain.c
> On Thu, Dec 27, 2012 at 2:31 AM, Milton Cezar Ribeiro <
> miltinho.astronauta at gmail.com> wrote:
>> Hi Mohamed and Markus
>> Mohamed, thanks for your reply, I will wait for a solution within GRASS
>> Markus, thanks for your reply,. Sorry  but I disagree a tiny bit,
>> because is expected that between a source and target I will find a
>> solution with the Least Cost path. Do you think that is there any
>> situation where a least cost between source and target will not be
>> found? Maybe if other software provide the soluction, although is not
>> the bestest option, I prefere receive one complete output than a
>> broken one.
>> Happy new year!
>> miltinho
>> 2012/12/23, Markus Metz <markus.metz.giswork at gmail.com>:
>> > On Sun, Dec 23, 2012 at 7:07 PM, Milton Cezar Ribeiro
>> > <miltinho.astronauta at gmail.com> wrote:
>> >> Dear all,
>> >> I am running a least cost path analysis combining r.cost and r.drain.
>> >> But on some cases, when the least cost path between source and target
>> >> reach the border of my map, r.drain stop on that position, and target
>> >> point isn´t reached.
>> > This is correct because at the borders, the direction can not be
>> > determined, the path could lead out of the current region, you can not
>> > tell.
>> > Running on other softwares the algorithms the
>> >> source and target is connected using edges without problem.
>> > If in doubt, I would call it a bug in that other software.
>> >> Any hint are welcome.
>> > Try to expand the current region
>> > Markus M
>> Miltinho - mcr at rc.unesp.br
>> Laboratório de Ecologia Espacial e Conservação - LEEC
>> Depto de Ecologia - UNESP - Rio Claro
>> Av. 24A, 1515- Bela Vista
>> 13506-900 Rio Claro, SP, Brasil
>> Fone: +55 19 3526-9647 (office)  19 3526-9680 (lab)
>> Cel: 19 9853-3220 / 19 9853-5430
>> Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
>> PG ECO & BIODIV
>> http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
>> CV
>> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
>> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Regards,
>    Rashad
PG ECO & BIODIV http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
