[GRASS-user] v.to.rast in a python loop, error
Scott Sinclair scott.sinclair.za at gmail.com
Wed Feb 8 06:46:33 EST 2012
On 8 February 2012 11:35, Johannes Radinger <JRadinger at gmx.at> wrote:
> I try to run v.to.rast of a line in a loop
> to get a raster for each attribute of the vector (multiple columns).
> Therefore I created a short python script, which is working
> expept for that I am getting error messages:
> ERROR: option <output>: <raster_attribute> exists.
> Here the code:
> #!/usr/bin/env python
> import sys
> import grass.script as grass
> import grass.script.setup as gsetup
> def main():
>    for i in ['FULL_HYDRO','LENGTH']:
>        grass.run_command("v.to.rast",
>                    input = "streams at PERMANENT",
>                    output = "rast_"+i,
>                    type = "line",
>                    use = "attr",
>                    column = i)
>    return 0
> if __name__ == "__main__":
>    sys.exit(main())
Have you tried adding flags = '-o' as an argument to
grass.run_command? That will overwrite the output raster if it already
exists.
Cheers,
Scott
