[GRASS-user] problems with colors resulting of an image fusion
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 9 13:16:49 EST 2012
On 09/01/12 00:50, Markus Neteler wrote:
> On Fri, Jan 6, 2012 at 5:42 PM, Moritz Lennert
> <mlennert at club.worldonline.be>  wrote:
>> Hi everyone,
>> I have some troubles with image fusion through IHS transformation of a
>> Landsat image.
> Hi Moritz,
> could you please post the procedure you used?
The same procedure as the one you describe in the book, i.e. the
classical i.rgb.his & i.his.rgb approach with grey.eq color table for
the resulting three bands.
I'll try to write up a reproducible example, including relevant data if
the NC set does not show the same behaviour.
Moritz
