[GRASS-user] m.viz.image Command Line
Rich Shepard rshepard at appl-ecosys.com
Mon Jan 16 21:11:47 EST 2012
Martin,
   I see that you're the lead author of m.nviz.image so you're probably the
best qualified to teach me the appropriate command line syntax to achieve
what I need for a project. I've read the man page and tried filling in the
data entry widgets in the wxGUI but keep running into errors I don't know
how to resolve.
   What I need is a 3D-perspective view of a portion of a drainage basin. It
would be nice to have the z-values increased 2 times to make the topography
easier to see.
   There are 2 raster maps: aber5m is the DEM/elevation map, and mompano_rast
is a raster version of the lakes vector map (because an area map will not
display in the wxGUI in 3D mode). There are also 2 vector maps to drape over
the rasters: streets (line color black, line width 1) and streams (line
color blue, line width 2) and a points map (proj_pts; color/fill color red,
icon diamond, size 8 in regular 3D view; no idea of the appropriate size in
m.nviz.image).
   There are many options for the command line and I have no idea which to
use or for which the above rasters, vectors, and points are the appropriate
maps.
   I'd greatly appreciate guidance on producing an output map given these 5
input maps.
Regards,
Rich
Richard B. Shepard, Ph.D.          |   Integrity - Credibility - Innovation
Applied Ecosystem Services, Inc.   |    Helping Ensure Our Clients' Futures
<http://www.appl-ecosys.com>     Voice: 503-667-4517      Fax: 503-667-8863
